Detail Tool Plan Marker
I'm having a hard time figuring out how to show the detail marker boundary (using the rounded rectangle marker polygon) at an angle. It seems that if I rotate the tool, or stretch the boundary, or change the boundary to a polygon, that the "clipping path" always draws lines parallel with the original grid lines. This also true if I rotate the plan view. Anyone else experiencing this problem?
Thanks in advance!
David Shorter
ArchiCAD 15 introduces a new control into the detail marker see attached
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
Perfect, thank you!
David,
Cool. You should add that to the list of undocumented v15 changes (I presume that's not advertised anywhere).
http://archicad-talk.graphisoft.com/viewtopic.php?t=36880
Jared Banks, AIA
Shoegnome Architects
