Detail annotation
Ferre
How do I get these text lines with dots like in the picture. I already tried with the label tool, but it doen't do the job as I want to. Is there a better solution to make those lines without the label tool?
2 REPLIES 2
You need to get someone to make you a custom label object to achieve that. Someone that is an expert in GDL scripting, which sadly I am not. There would be several people on this forum that would have the capability of creating that for you.
I also wouldn't try to achieve a manual work around as it would become a big burden to manage and changes and would be very time consuming placing them for every piece of text.
Nathan Hildebrandt fraia
Director | Skewed
AC6 - AC28 | WIN 11 | i9-10900K, 3.7Ghz | 32GB Ram | NVIDIA GeForce RTX
3070
Erwin Edel
Label tool works fine, see attachment.
If you want extra bullets, those you can draw with a line with 'arrowhead', but instead of arrow you use a circle.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
