Detail empty from section / elevation
David Bearss
Am trying to generate a simple detail from a cross section or elevation view. When I select to view the detail the window is completely empty. Turning on all layers and selecting the correct renovation status has no effect. Generating a detail from plan view works fine. Am I missing something here?
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
0 REPLIES 0
