Diferents Elevation on Windows in the Same floor
Hi everybody, i have an issue about working in a project the fact is that i have some differents windows heigh in diferents elevation, then when i'm in the floor plan i can only see the windows that correspond to the floor plan cut plane, and i have to see all the windows. there any way to see diferents windows elevation in floor plan unlinked to the floor plan cut plane option
I have this questions as well.
I am wondering if you can deal with it thourgh reference levels.
But I think not, though I donnot know much about them, but I think I should learn what they are about, cause it may save me some woes.
I have learned that you can show your window as symbolic to make it show if it is above the cutplane, but I think you have to change the way your wall is being displayed- Project, project w/overhead, I dont remeber which gets you what you want.
I think you can also display it as overhead all, and make your overhead lines show as solid.....
But, i haven't found a way that really satisfies me, because what ever I do to make it show, it does not show the same as my other windows do.
I am listening here as Well my friend.
You can play around with the cut plane parameters, of course, but have you tried "symbolic" display?
Richard
AC26 (since AC6.0), Win10
