Sorry if this is a question with an obvious answer...in brief, I am trying to publish a layout dimensioned in decimal inches in a project which is overall in feet and fractional inches.
In AC14, within a project where the working units are set as feet and fractional inches, I have a layout I would like to publish with dimensions in decimal inches.
If I temporarily change the project settings > dimensions to decimal inches, the dimensions appear correctly in the worksheet (what I am trying to dimension is a hotlinked module with dimensions set as fractional inches), but not in the layout.
I have tried to manipulate whatever settings I could find to change the dimension units locally (to the layout), without success.
Is this something which I am unable to achieve because of ignorance or poor research, or should I be able to do this?
Thanks for any advice.
