Eman
Dimensions
I am a beginner and first thing that I need to know is about dimensions.
I am setting the dimensions to metres and then when I draw a wall and I enter 5 (metres), the wall it is not coming 5 metres. maybe it is coming 5cms or inches!
Thanks
Eman
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
1 Solution
Eduardo Rolon
Looks like either you didn't set the units correctly (look f or Project Preferences -> Working units) or after clicking to place the first point of the wall you didn't input the distance correctly by using SHIFT+R 5, enter.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
Eduardo Rolon
AC29 US/INT -> AC08
Eman
ejrolon wrote:
Looks like either you didn't set the units correctly (look for Project Preferences -> Working units)
Hi Ejrolon,
Yes you are correct, I didn't set the units in working units. Now it's ok.
Thanks for your reply.
Eman / Draftsman
