Display Order issue with columns and walls.
Nicholas Jones
Hi, am new here but have lurked for a long while, thanks for the help!
So I have a plan where my columns are stacked below my partition walls and no amount of display order tinkering can get them on top, I understand that these elements are of the same classification in stacking order so bringing forward should work to stack the walls above the columns, this has always been the case for me but now even if I bring the columns to front and send the walls to back the appearance is the same.
What am I missing?
AC25 solo UK • 2017 MacBook Pro 15" 2.9GHz Quad-core i7 16 gb ram
OSX10.15.5
1 REPLY 1
Nicholas Jones
Nevermind! I solved it, this was an effect of the floor plan display, I didn't realise that 'outlines only' would make it appear to be stacked behind, It's all just an illusion.
OSX10.15.5
