kevin b
Display Order within Composite
Is there a way to change the display order of a skin separator line within a composite?
We have some composites used for walls and to show rated assemblies, we have split the core of the composite in two and set the skin separator to be the line type and color we use to show rated walls. However at a small scale on our egress plans where the width of the separator pen graphic is wider than than the actual width of the wall, which is what we are trying to achieve on these plans, we want the graphic to be forward of the wall edges.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
There's no way to adjust the display order within the composite but you might be able to get what you want by adjusting the wall outline pen to a hairline (0.00 lineweight).
