Display of floors overhead
How do you control the outline display of floors overhead please?
I have a mezzanine floor above the ground floor level that I want to show the outline of in a dash dot linetype.
At the moment it is indicated as a dash linetype.
I don't seem to have the same visibility controls as I do for roofs/canopies above, that I have indicated as a dash dot linetype by using the 'overhead lines' options.
3 Replies 3
David Maudlin
thompsonmp:
Look at Project Preferences > Legacy, the line type for Slabs, Meshes and Objects above and below story are managed here.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
thompsonmp:
David
Perfect thanks David
David Maudlin
thompsonmp:
Glad that worked for you, thanks for posting back. Another option is to use a Graphic Override, which would not be as universal as the Legacy setting.
David
