Distance Guideline
Red
Is there a way for the "Distance Guidelines" to reference each side of the core? I thought it might be able to by turning off the wall finishes, but it still goes to the finish as if it was still turned on.
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
7 REPLIES 7
Not that I know of.
You are not the only one that has noticed this.
https://community.graphisoft.com/t5/Documentation/New-Smart-Guide-Feature-in-AC27/td-p/401094
Be sure to pass your thoughts on to your local Archicad support.
The more that report this issue, the more likely it will be looked at.
mthd
Hi, a simple work around for now is to allow the wall thickness with your room dimensions. 10mm wall linings add 20mm to your dimensions ie for 3600mm wide room add 20mm or a total width of 3620mm and so on. Till they add a setting for DG’s to measure to stud core edges.
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
Certificate IV Architectural & Building
Technology, (Estimation & Administration).
or just learn to use the tracker which doesn't suffer from all the DG restrictions/failures.
Yes true but why not have multiple trackers running simultaneously with DG’s ? That way we can use our tracker tricks with DG’s to give us a location, less clicks less time more productivity.
This video shows the use of the tab key in the DG display, it also works with other tracker inputs too.
https://www.youtube.com/watch?v=nT36TWx5u4A
Yes it definitely needs to be able to measure to the frame as well as to the outside of walls.
DVH
Any chance there is an orthogonal grid option and rotated grid option for distance guides.   I have a huge section of the model that is set to a rotated grid and the distance guides do not acknowledge those walls that align with the rotated grid.  It will pick up columns as a reference but they will only pick up the corner of the column.  Hope you have some insight.
Dwayne Van Horn - Architect & AC User Since 1994
AC_27 MacBook Pro M3 Max, OSX 14.3
Levin Brown Architects, 2016- Present
Hi @DVH, I haven’t tested it in that way just yet. I know it is still being further developed for AC28. I would ask a GSC administrator for what it can do right now and we just have to wait till AC28 technology preview to see what it is capable of.
Distance guides do not work (at present at least) with angled walls.
Does it help if you rotate the screen so the rotated grid/walls now appears square?
That makes it much easier to work on that part of the plan anyway.
Then just toggle between screen rotation angles.
