Documenting elements attributes in 2D view
I just finished a fairly complex ductwork layout and output the results to a (PDF) transparency.
The print is quite useless in that does not include any quick, verifyable information of any given ductwork section or structural member.
Ultimately, I would like to:
a) draw some ductwork, piping, etc.
b) create a 2D view where some of the ductwork attributes show up in text form, such as size, height from floor, beam size. etc
c) print the view.
Is GDL a possible avenue to explore ?
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
David Maudlin
Conrado:
You have 2 avenues to explore:
1. Add a parameter(s) to the objects(s) that can turn on this information in the 2D view, then edit the 2D Script to display text (Text2 command) with this information. With additional work, turning this text on and off could be linked to a Model View Option.
2. Create a Label that displays the information of the object it refers to. The labels then can be placed on a layer to control the information's display. This would also work for non-object elements like Beams and Columns if they are used for the structure (rather than objects).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks for your tip, David.
Give yourself a virtual cup of java on my behalf.
