Does Archicad 12 worth upgrading ? (from V11)
Is it flawless relatively ? or is quite provlematic.
didn`t find any reference.
thanx
7 REPLIES 7
thanx !
does ac12 has plugin for Cinema 4D ?
Eduardo Rolon
Todavía
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Hola
todavia que?
hay o que no hay?
es el primero porque uso con el c4d
gracias
Eduardo Rolon
Todavía no ha salido el plugin, puedes usar 3DS u OBJ.
As far as I know the plugin for AC to C4D does not exist yet.
AC28 US/INT -> AC08
another Moderator
thanx
can I ask u if r u satisfied with ac12?
Eduardo Rolon
Except for the plugin, Si estoy satisfecho.
AC28 US/INT -> AC08
another Moderator
