Does Special Menu still exist in AC23?
I tried to activate the Special Menu in AC23 (there is still a registry entry for it), but it wouldn't show up in the list of available menus.
What I really need is the "Show Penetration Line" command. Is there an alternative to this now?
Richard
AC26 (since AC6.0), Win10
Hi Richard. There is a preference entry for it in the Mac preferences, too, but I see the same result - enabling it does not make the Special Menu (or its commands) available in the Work Environment.
I haven't used this 'show penetration lines' solution in a really long time... ever since Solid Element Operations and improved trimming made it easier to model things properly. For example, way back when, it was easiest to model a chimney during design development as walls simply penetrating a roof ... and this Special Menu command made the roof edges at the penetration visible in elevations / 3D.
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks for checking, Karl. Looks like it's going to be SEO then, although the penetration lines would have been so much better in this instance.
Richard
