Learn more
Dome problem
I need to create a dome made of 8 vertical segments (it's octogonal in the floor plan) but I need its height to be larger than its radius.
The problem is that while creating a dome using roof tool the height is limited and cannot be bigger than the dome radius. It applies to any kind of dome, round or octogonal.
What or how should I do it to have, let's say, a dome with a 1m radius and 3m high.. ?
thanks!
p.s. I tried to use profiler but I can't get it to work with specific number of segments, it works only with a round one. Maybe I'm missing sthg.
2 Replies 2
You done the job 1/2 (Profiler). Now draw an octagon in Plan, next select a WALL tool (with your Profile) and spacebar+click on the octagon.
That´s it.
Thanks andro!
