Door Object put in walls?
http://archibaseplanet.com/gdl?category=12
I had downloded some of this doors, i know that they are objects but it's any trick to put this object in walls? like a normal door?
David Maudlin
jonyyybe:
You could try opening the library part and changing its Subtype to Opening > Wall > Door, but this may need additional editing of the scripts to work properly. Two other options:
1. Select a door that that supports Custom Panels and try saving your part as a Custom Panel to use with this door.
2. Place an Empty Opening, then place this object on a 3D only layer for 3D, draw the plan symbol with 2D tools.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
david thanks for the fast answer, i was thinking of this solution too, but i thought there is another solution. something triky.
