Door Open Direction in Elevation View
The triangle on the door shows the door direction in the elevation view. However the display in Archicad is opposite from our habit here. Are there any ideas for changing the triangle in the Archicad?
Picture A- Door Display in Archicad
Picture B- Door Display in China
5 REPLIES 5
In the Options for GDL Objects panel of the Model View Options Dialog you can find the Line Orientation field.
This is the field that controls globally how Opening Lines are displayed. The "Hinges" option will give you the result you want.
Hy,
Yes you can, see the attached image
Regards, Ede
OK, so the full answer is that by default this is controlled by the Model View Options setting.
However, you can go to the settings dialog of the Door, check the Override Model View Options checkbox and then you can also individually override this setting for selected Doors.
Thank Ede Abos & laszlonagy for sharing the great tips!
