Stress Co_
Door Problem
I need a 4' closet door (a pair of 2 footers). The best door I found in the Archicad 9 Library is "D2", but anything under a 5' opening gives a 2'-6" door and another, the remainder of the opening width (in this case 1'-6"). Am I missing a setting somewhere?
The door is found in: Object Library 9> 08 Doors-Windows 9> Doors 9> Wood Plastic Doors 9 > Wood internal Doors> D2
Thanks
Marc
Marc Corney, Architect
Red Canoe Architecture, P. A.
3 Replies 3
Tom Krowka
Go to the door properties, then door panel, panel division type, proportion, 50/50.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
Stress wrote:
...but anything under a 5' opening gives a 2'-6" door and another, the remainder of the opening width (in this case 1'-6")...
Marc,
There are 2 possible ways to handle this:
1.) In the Door Panel parameters change the "Panel Division type" parameter to "Proportion" and then make sure the "Right Panel/Total Panel Opening" parameter is set to 50
or do this:
2.)In the Door Panel parameters set "Main Door Panel Width" to 2'-0"
curious that they give two ways to adjust the same relationship - kinda' confusing
Stress Co_
Dan / Tom:
I looked at that parameter about 5 times and thought it was somehow associated with the "panels" on the door panel.
Next time ... I click everywhere.
Thanks for your help.
Marc
