3 hours ago
- last edited
an hour ago
by
Claudius
It must be a bug or..?
In ArchiCAD 28, I can no longer "override" a single door and make one door more detailed than, for example, all other doors?
This is a function I have used repeatedly over time. It seems that detailing is now exclusively controlled via MVO and cannot be done specifically for a single door ?
I think that's a huge drawback if that's the case?
Does anyone have suggestions for another way to solve it?
[Topic title edited by moderator to be more descriptive. Original title "Door settings"]
2 hours ago
SInce archicad 28 , all settings related to MVO are moved to MVO panel, you cannot control individual elements MVO
2 hours ago
The problem is that, not all settings have been added to the MVO panel, and so there are some settings that you cannot use in the AC28...
This is unfortunately a huge step backwards from previous versions.
The intention is not necessarily bad, but the implementation was not good.
Gábor
an hour ago
Thank you for the response! If that's true, it's really a huge setback for ArchiCAD 😳
As a long, long-time ArchiCAD user, it's a feature I've always used.
Why has it been removed?
Are there any alternatives?
