Door
Hi there,
Could you please tell me where I went wrong with the door frame fill? I set everything to 1 black, but this part of the door shows thicker than the other parts.  Thank you
2 ACCEPTED SOLUTIONS
Yves
Hy,
The opening lines pen is set in MVO
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Yves
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
6 REPLIES 6
Yves
Hy,
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Hi Yves, thanks for the reply. Could you please show me where Ittings? It seems that your Archicad is in a different language, so it's hard to find exactly where the setting is. Thanks. can find the se
Yves
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Sorry Im still confused☹️. could you explain more?
Yves
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Thanks ☺️
