Doors and Window defaults
Can we set our own defaults on the doors and windows library so that each time we get a door or window it will not have the opening line on the 3D view on (under accessories) and on the windows can we default the frame width etc. (under Structural Dimensions), to be the measurement we want. We have to change it each time we get a window.
Thanks,
Westrick Design
To change the defaults you would have to get in and change the settings in the parameters area of the objects script (for each window). The settings in the actual objects script that are current are the ones pulled as defaults (not settings in the macros).
A short cut for this is the use of favorites - set the windows up and use the favorites window rather than the tools.
