capearch
Doors in 3D
Can the door itself be turned off in 3D and still maintain the opening and the casings?
3 Replies 3
Yes, select 'empty' under 'Door panel' in the door settings. This will leave just the frame and casing visible.
If you want everything off and just leave the bare opening, turn the '3d Detail level' to 'off'. This gives you the option of turning the door back on again rather than use an empty opening.
capearch
Thank you very much Peter for your quick response and solution. Been using ArchiCAD for many years and had no idea. Just tried it and it works beautifully. I'm very appreciative.
Jeff Smalley
No problem Jeff, I'm glad I could help!
