2006-07-14
05:27 PM
- last edited on
2023-05-23
05:15 PM
by
Rubia Torres
2006-08-16 11:36 PM
2006-08-17 04:37 AM
Peter wrote:Many thanks, Peter.
Rod,
The font is called "MrHand".
Peter Devlin
2006-08-17 04:49 PM
Peter wrote:I just changed the Macro to test the results, and promptly set it back when it did not work.
Laura,
I do not recommend changing a macro because I don't know what
the implications of any change might be as these macros are used
in many objects.
Peter wrote:
What is the problem with the store front object you refer to ?
Peter Devlin
Laura wrote:The door on the left in the attached image has it's opening angle in 3D set to 0.20. The door on the right is set to 0 degrees. As you can see, there is no delineation between the door panels nor the doors and the frame.
I'm also having this problem with the line between the door and frame not appearing (specifically with the Storefront objects, which assume that the face of door aligns with the face of frame). Setting the opening angle in 3D to 0.20 gets me the top line, but not the lines to either side of the doors.
2006-08-18 03:24 PM
2006-08-18 05:37 PM
Tom wrote:Yes I had, thanks -- I suppose it's a possible short-term solution, but I really think that GS needs to address this and we should not have to take it upon ourselves to be customizing a number of our library parts -- LJY.
Have you read this thread:
2006-08-18 06:41 PM
2006-08-18 06:59 PM
2006-08-18 07:13 PM
TomWaltz wrote:On both sides? In principle that should only work on the hinge side.
It is definitely annoying, but I've just been setting the 3D opening on double doors to 1 or 2 degrees. They look the same but generate the line down the middle.
