Display malfunction of Graphisoft ID dashboard
Learn more
Dragging a Copy / Profile Offset Modifiers
Hi all,
When dragging a copy of a wall, or the like, is there a way to clone the exact profile offset modifiers as well? At the moment, it resets all the values to default. I'm pretty sure I've been doing it for a long time, but only recently it seems to have changed. Either that, or I've never even noticed.
Any help would be appreciated, thanks
4 Replies 4
You mean dragging a copy of the wall in the model (plan or 3D)?
If so that should give you an exact copy of the wall - modifier settings and all.
Nothing should change or reset.
Only when changing the profile to a different one will the modifiers reset to default values.
At least that is what I am experiencing.
Dragging a wall on plan view and nothing more
Seems like the issue happens only on certain walls. I have no idea what is causing the issue. Some walls it'll reset, some it'll keep.
Any ideas what could trigger this?
No sorry.
I haven't had any trouble so far.
Ugh, this isn't ideal. It's probably because there's a few different skins on the complex profiles. I think it's a model problem, and not a works environment one. Hopefully it doesn't come back to haunt me too much down the road..
Thanks for the response
