2010-06-10 01:29 PM
2010-06-10 09:39 PM
2010-06-11 03:39 AM
2010-06-11 03:59 AM
2010-06-11 05:16 AM
2010-06-12 06:14 PM
2016-05-16 02:11 AM
s2art wrote:Just remember, you also need to set your working units for angles to Hours Minutes and Seconds (Options/Project Preferences/Working Units) while using this method. ArchiCAD will not otherwise accept spaces in pet pallet/angle dialogue
Another way, which is similar to Andrews, but does away with the mirror-ing at 45degrees step:
1. Click to start the line.
2. Drag your cursor in the direction of north (constrain with the Shift key).
3. Hit the R key, input the length.
4. Hit the A key, input the angle from survey (with spaces between degrees, minutes and seconds - if its 0 seconds you do not have to put in the 0)
5. Then hit the -(minus) key and hit ENTER.
This has the effect of adding your bearing to the north direction. You use the minus key as Archicad measures angles anti-clockwise, survey goes clockwise.
This method also works with the Cadimage Survey Boundary object, for those who have it.
Hope this makes sense.
2016-05-18 09:08 AM
2020-04-21 03:41 PM
