2011-05-26
02:50 AM
2023-05-25
04:51 PM
Rubia Torres
2011-05-26 03:09 AM
2011-05-26 04:02 AM
2011-05-26 04:15 AM
2011-05-26 04:18 AM
2011-05-26 04:48 AM
2011-05-26 05:12 AM
assume I have a survey/site plan/universal dimensions/boundary lines/anything I might happen to want to see all the time in all the drawings.
2011-05-26 05:40 AM
2011-05-26 05:55 AM
NickMcLeod wrote:Whilst both are good solutions, my vote (its what we do) goes to Links suggestion of Hotlink modules. You can set up either a Publisher set view to publish the common elements from one story and link into the others, or group them and manually save as a Hotlink Module. Has the advantage of actually placing the elements on the floor you are working in so you can dimension to them, etc. I find Trace Reference can slow you down quite a bit if the reference is heavy on detail
Barry wrote:Hey Barry,
While working in Archicad you can't see the combined image on each storey unless you use the Trace Reference and set the site plan as the reference.
That solution is simple and perfect.. Exactly what I was looking for.
Fundamentally its not a problem whilst working on the drawing, but to have to replicate elements, or create symbols, or do any other types of workarounds just so you can see what you've drawn on the layouts is inflexible and dumb. Your solution is elegant and does exactly what I need. So thanks.. For the non-ArchiCAD specific, lateral thinking solution.
Nick.
2011-05-26 05:57 AM
