2007-11-14 12:08 AM
2007-11-14 12:15 AM
2007-11-14 12:51 AM
2007-11-14 01:05 AM
2007-11-14 01:15 AM
Link wrote:I wish it would come in that way.
It should come in cropped to the saved zoom extents by default. This is regardless of what the drawing defaults are.
So you tried changing it via the Drawing's Settings> set Frame to Manually resized frame. Is your drawing a long way from the project origin?
Do you have the latest version of AC11?
Link.
2007-11-14 01:20 AM
2007-11-14 01:20 AM
2007-11-14 01:39 AM
Link wrote:I had to get rid of the trace reference and go through the process of merging the .pln that I created from the origin corrected .dwg.
900,000 feet! What is that - 170 miles? Are you designing an oil rig by any chance?
I wonder if your trace reference was on, when you saved the view, and if you turn it off and save it again, will it make any difference?
Link.
2007-11-14 01:42 AM
~/archiben wrote:Wow.
in your Preferences>Layouts make sure that you have ticked the option to adjust each drawing frame to the zoomed area . . .
~/archiben
2007-11-14 01:50 AM
