To merge in LINE TYPES and FILLS, you'll need to use ATTRIBUTE MANAGER...usually found in the options menu.
1. Open up your converted detail file.
2. Goto Options/Attributes/ATTRIBUTE MANAGER
3. On the RIGHT side, click the OPEN button
4. Navigate to the AC10 Template File
5. Choose the TAB for Lines (or fills,etc)
6. SELECT ALL on the right side
7. APPEND to the Left Side
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
