2005-01-06 06:30 PM
2005-01-07 05:02 PM
2005-01-07 05:22 PM
2005-01-07 05:29 PM
Aaron wrote:How do you do it? I have tried and cant figure it out.
use the 3D window to tilt it in the proper orientation and save it as GDL objects.
2005-01-08 12:16 AM
patricprz wrote:Make the object in plan then view the elements in 3D changing the orientation to match that of the proposed object ( generally elevation view from the top) While the 3D window is open save (as object),
the purpose:
Can you rotate objects around the X or Y axis? For example if i draw a ornamental lintel with the slab tool in plan view, how do i then rotate it around the X axis so i can use it in elevation?
2005-01-08 02:24 AM
2005-01-08 02:43 AM
2005-01-08 04:04 AM
patricprz wrote:Read my post preceding yours ...
Does anybody know of modelling tutorials for AC?
2005-01-08 04:44 AM
2005-01-10 09:01 AM
2005-01-10 11:38 AM
