‎2005-01-06 06:30 PM
‎2005-01-10 03:45 PM
‎2005-01-10 04:06 PM
‎2005-01-10 05:06 PM
‎2005-01-10 07:16 PM
Aaron wrote:... and, if the object has the rotation parameter, you can check it in the S/E and adjust it correctly.
Patrick, placing objects on a ramped surface is done using the Gravity tool. It works with slabs, roofs or meshes,
Slect the obejct, activate the gravity tool and select the surface type to be "gravitated".
‎2005-01-12 02:20 PM
‎2005-01-15 05:17 PM
‎2005-01-16 01:30 AM
patricprz wrote:This is where understanding some of the GDL code is useful. Archicad automatically makes the hole in the wall to suit the overall size. By adding the WALLHOLE command you can shrink the hole opening to suit.
To create an edwardian window do i have to create the frame surrounding the window seperately as an object and place in front of the actual window?
WALLHOLE 5,1, 0,0,1+2+4+64, width,0,1+2+4+64, width,height,1+2+4+64, 0,height,1+2+4+64, 0,0,1+2+4+64someone else may better advise on the "1+2+4+64" parameters as they comptrol which edges are visible
‎2005-01-16 02:54 PM
‎2005-01-16 05:17 PM
‎2005-01-16 06:26 PM
Link wrote:
Also worth mentioning is that there is no longer any need to view these objects from 270 degrees in the 3D window. If you are saving the part as a window or a door, it's shape is actually determined from the floor plan.
