‎2006-02-16
06:17 PM
‎2023-05-25
06:19 PM
Rubia Torres
‎2006-02-16 07:09 PM
‎2006-02-16 07:58 PM
Jay wrote:We haven't had any issues with new construction. We end up modeling things as we want them to look and since we can control all the dimensions, there's no problems. As for renovation projects, we've pretty much tried to stayed away from the "fake" openings, though there's been places where we had no options.
...a framed wall with openings above stem wall. Then I place a Furring wall on the Subfloor and add the "fake" openings.
For Remodels I leave the existing wall on a "Walls (Existing.dem)" layer and create a Copy on the "Walls A" layer (this is a new construction layer). Modify the copied wall to be the Thicker Composite wall and modify any changed openings.And what do you do if the project is on the larger side with walls with varying widths throughout? Do you make yourself a separate wall for each condition? Gets to be a bit of a tougher work-around. That was actually the only other option we were thinking about, and we're trying to avoid this one also (kind of a tie with the "fake opening" one).
The only problem that I have had with the 2 wall occupying the same location, is when each of the walls contains a Wall Accessory veneer. New Work around for that......Haven't dealt with veneers yet. Had not so great experiences when we were experimenting with them for the interior (and some exterior work) wo we try to stay away from them. As for the intersection priorities, it's the only way to go. It's actually part of our standards.
‎2006-02-16 11:37 PM
Sergio wrote:I don't know if I understand. If you have a wall line with existing walls of different widths Group The walls that are to be modified and leave them on a "Existing (to Demo)" Layer. Copy walls to New Layer and Change.
‎2006-02-17 12:31 AM
Jay wrote:Yeah, I get this every once in a while...
‎2006-02-17 01:18 AM
‎2006-02-17 01:23 AM
‎2006-02-17 05:50 AM
‎2006-02-17 06:25 AM
s2art wrote:Not me. (I'm not sure what it would mean to vary the width of a composite? The skins presumably correspond to some actual materials. Which skin(s) would you thicken/shrink and how would that be interpretted?)
Wouldn't it be nice if you could have variable widths for your composite walls? Adjust the widths in wall settings instead of in Composites......
Anybody care to make a wish? (for AC11?)
‎2006-02-17 02:51 PM
