Drop down menus
My custom drop down menu is different for "options" than if I use the "Standard Profile" work environment. How do I change just the menu drop downs to standard?
I want to keep the custom toolbars I have created, but I would like the standard menus.
Hope this makes sense.
Thanks in advance.
Difference
Bruce
You can't set just the menus to the Standard profile...it will be the menus and the toolbars (Command Layout Schemes).
But, if you have created your own named toolbars, set the Command Layout Schemes to Standard, then change the toolbars back to what you want. Of course, save this as your preferred Commands Scheme.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Post moved to 'Working in Archicad' section.
