EDIT TOOL MISSING
Any idea why my edit tool is missing ? How do i get this back ?
See attachment - i can click on an element but i cant move , edit etc.. its greyed out somewhat.
Never experienced this before in AC.
please, thanks
As opposed to this image- here you see what it is I am missing ? the edit toolbar -..
Review your first attached image. There is a box that is telling you information about the object that you have selected or highlighted. Within parentheses, it reads (locked). An object can be unlocked by going to the pull down menu "edit" then "locking" then "unlock". Then you'll be able to edit the item as indicated on your second attachment. The ability to lock an item, can be a powerful tool. Archicad has a world renown Help index - both textual and videos - try to go there as often as you can, to fully understand aspects and nuances of the software that may not be intuitive or readily obvious.
