2008-02-19 08:50 PM
2008-02-19 10:08 PM
2008-02-19 10:25 PM
Peter wrote:Thats basically waht I already did, minus the story settings. Everything is already set to the correct height location, I just need to change the story level "line" so that it will read accurately on plans, sections, and elevations. All the geometry is set where it needs to be with regard to the overall model, but the story levels are off.
Have you tried turning on all the layers, setting the storey heights to the correct dimensions, then selecting all on each storey (on plan) and elevating it to the correct level (ctrl 9). You can use minus as well as positive figures.
Make a note of the actual distance you have to change each storey beforehand, to make sure you elevate the walls etc correctly.
