Efficient Keynotes
I am looking to find a better solution for drafting Keynotes on Construction Documents...
Has anyone found an efficient solution that works well? I have look at the Auto-Keynote Tool that is available from objects online... however... I'm not convinced that is is the solution that I am looking for.
Right now... I am drafting my own symbol shapes with the line tool and then using the text tool to identify the keynote symbol... and then typing all of the keynotes with the text tool all on a separate story and then placing that view onto the layout.
Any advice would be greatly appreciated.
-Thanks
3 Replies 3
Keynotes by CadImage
Thanks for the tip. I'll look into. Is the Keynote Manager Tool pretty quick to get going in it or does it take weeks of database setup?
-Thanks
The more Spec's you have the more it takes. I add the Spec's as needed and it grows before you know it.
Good Luck,
Joseph
