We value your input!
Electrical Pallet Archicad 11?
Gus
Does anyone out there have an electrical pallet module made using the Archicad 11 library symbols? If so, could I borrow it? I promise I will return it quickly.
Michael.
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
Erich
Gus,
Have you looked at the Electrigon object? Will that do what you need it to do?
http://www.archicad.ca/?p=70#more-70
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Gus
I looked it up and it seems that it might be a little more complex than I need. I'm only doing residential stuff and not paying attention much to all the other data that can be calculated in larger projects. The simpler the better really.
Madison WI
