2026-06-03 08:09 PM
Archicad 28 on a MAC platform. When trying to do the electrical plan, only some of the walls are showing up. I can inject properties from other walls that do show up. What's happening?
2026-06-03 10:49 PM - edited 2026-06-03 10:49 PM
reason elements show in one plan but not another:
-layer combinations
-renovation filter combinations
-design options
-floor plan cut plane
-home story (project map)
I assume this is a floor plan view, not a 3d document, but if it is a 3d doc, that could be the 3d/plan view setting the viewpoint was built from
2026-06-03 11:28 PM
It's not a 3D document. It's a 2D floor plan, and only some of the walls are showing up. Same things is happening when I attempt to make an engineering plan. Tried adjusting the 3D/plan view settings, but none of those settings work
2026-06-03 11:32 PM
This is what it looks like
2026-06-03 11:55 PM
The walls show up if I inject properties from 1 wall into another. But, no windows or doors show up. I've been playing with the renovation filters, but no luck so far
2026-06-04 12:39 AM
is your floor plan cutting plane at the right height so it passes through all the walls?
2026-06-04 03:15 AM
Looks like you have walls below your Cutting Plane. You can either edit your Cutting Plane for the relevant Views so that it cuts all of the walls in question when they are set to so on All Relevant Storeys, or have a wall on every storey that you want it to show on, and set the Floor Plan Representation to Home Storey Only Symbolic.
Ling.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
