2018-05-30
07:33 PM
- last edited on
2023-05-25
05:35 PM
by
Rubia Torres
2018-05-30 10:50 PM
2018-05-31 03:04 PM
2018-05-31 05:57 PM
kittonian wrote:What I was saying, essentially, was that only a FEW surfaces have a fill already associated with them. Clearly, your running bond brick and wood 00 do, but most do not -- at least out of the box -- which is probably why you don't see anything for most building materials. Building materials have TWO places to define the fills: one for cut planes, and one for UNCUT planes. (see my screen shot) The UNCUT fill pulls its hatch from the surface definitions, which usually don't have a fill. I doubt you have found a bug.
Thanks Richard. I re-read my original post and perhaps I should have been clearer. If I set the surface to use the common running bond brick vectorial hatch, or wood 00, it shows up, but setting it to lightweight concrete or virtually anything else did not.
Definitely a good thought, but I think this one is a bug that needs to be verified by the community.
2018-05-31 06:40 PM
2018-06-01 02:51 AM
2018-06-01 04:12 PM
2018-06-01 08:42 PM
2018-06-01 09:12 PM
2018-06-01 09:32 PM
