Elevation Markers
I am using the built in elevation maker, I can control the size and shape of the marker head but can find no where to change the settings of the line between the marker head... or just turn it off altogether.
Any clues?
Its the blue line in the attached image that I am trying to control / change.
Thanks in advance,
Matt
David Maudlin
Matt:
For the Elevation Tool (as opposed to the Section Tool), the line between the markers is a non printing Marker Range line. It can be turned off by disabling the On-Screen Display Option Marker Range. Its color and line type can be changed at Work Environment > User Preference Schemes > On-Screen Options > Line Type and Pen of Marker Elements' on-screen-only parts.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Brilliant, sorted, thanks.
