‎2007-11-05 11:57 AM
‎2007-11-05 01:32 PM
‎2007-11-05 01:39 PM
‎2007-11-05 02:31 PM
‎2007-11-05 03:20 PM
‎2007-11-05 07:07 PM
TurboGlider wrote:It may a curtain wall bug, but I've also had random shadow problems with windows and cadimage wall accessory cladding. On the windows, I've had a whole sash shadowed when it should be only partially in shadow and my wall cladding accessory at one point shadowed a single clapboard on one elevation.
I think you got a 'bug' in your object for that curtain wall, we got the same problems with shadows in Swedish version of ArchiCad 10 for some of the curtain wall. I found the problem in our object, but it was long time ago. But if you are familiar with GDL check the GDL code for that object. I almost sure that the problem is there even for you.
