Srinivas
End Cuts With CAD Image's Profiler
I am using CAD Image's Profiler and I want to make a custom beam where the vertical end cut should be as shown in the image.
How can I do that?
Thanks in advance.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
5 Replies 5
I haven't used Cad Image's Profiler, but you can achieve that result using Solid Element Operation. Create an operator (a slab for example) which you use to cut the end of the beam. Then place the operator on a hidden layer (don't delete it). And that should do it.
Srinivas
Thanks Adytc, but the problem is the beam is an inclined one.
I am looking for an easier work around.
Many Thanks.
ArchiCAD Service
Mac, Windows 11
An SEO is about as easy as it gets, but another way would be to use a polygon marquee to cut the beam where you want, show the beam in a 3D window, and save from there as a GDL object.
Richard
AC26 (since AC6.0), Win10
Tony Krepler
Hi Srinivas,
Unfortunately, the current version of our 3D profiler is not able to handle the concave angle you are referring to. It is a good idea though so we have put it onto our wishlist for future releases.
Until then, please use the workarounds suggested by adytc and Richard Morrison.
Tony Krepler
Product Manager
Cadimage Tools Limited
ArchiCAD Productivity Tools
:: Auckland
:: New Zealand
:: [email protected]
:: http://www.cadimagetools.com
Srinivas
Tony wrote:
Hi Srinivas,
Wow Nice to hear that.
Thanks to all you guys.
ArchiCAD Service
Mac, Windows 11
