‎2005-05-03
12:55 PM
‎2023-05-25
06:20 PM
Rubia Torres
‎2005-05-03 02:56 PM
‎2005-05-04 03:51 AM
keshav wrote:means that you're probably loading the archiCAD 8 library many times over. check your library usage. and paths to libraries are important to maintain for all users - they can easily get out of hand on a team project if the teamleader status is abused!
1. Duplicated database name "AC_8_US" at line 1 of file MASTER_GDLAC_8_US.gdl.
We are also getting errors while switching from 2D to 3D. These errors are below:every object that is calling on your duplicated master GDL file is just letting you know that it's found a few to choose from when it's being generated! (because of the multi-libraries loaded)
[etc]
Can't find Macro: D Saracenic Opening, calledyou have a macro (kind of like a sub-object) missing in your library object 'sri monument2.gsm'. is this object custom built and does it contain other 'objects' that are no longer in your libraries?
at line 205 of file sri monument2.gsm.
Can't find Macro: sri, called
at line 319 of file sri monument2.gsm.
at line 335 of file sri monument2.gsm.
at line 351 of file sri monument2.gsm.
[etc]
‎2005-05-05 02:18 PM
means that you're probably loading the archiCAD 8 library many times over. check your library usage. and paths to libraries are important to maintain for all users - they can easily get out of hand on a team project if the teamleader status is abused!Hi! Another newbie here with the same message but I'm afraid I'm so new that I don't follow your suggestion. I did go to Library Manager and unloaded and reloaded some Libraries but the problem returned. I'm a single user with a Demo version and would appreciate any help available on this. i.e. How to maintain the path to the libraries?
‎2005-05-05 04:42 PM
‎2005-05-06 02:55 AM
‎2005-05-06 03:06 AM
‎2005-05-06 03:13 AM
Architeria wrote:architeria
I get a classy looking Library Loading Report that says I have Missing/Doubles. And when I right click and paste here I was quite surprised to get the following, but that is what it says.
‎2005-05-06 03:31 AM
‎2005-05-06 04:45 AM
