In the error message(if there is no Object name) you have, at the end, a text in brachets. That is the
object ID. You can review it later, if you need, opening the Report window (last command in Window menu).
You can search for it with the
Find & Select command. If the error caused the object to be completely absent from the 3D model, you need to search it in ALL the floor plans.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
