Essential Training Guide for AC14
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-03-31 11:56 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-01 03:59 AM
Just sounds like you don't have the Movie Player set to show in your Work Environment.
I just checked the "Standard" work environment and I couldn't see it either.
To add it open the Work Environment dialogue.
Select the MENUS on the left hand side.
Open the OPTIONS menu on the right hand side.
Sort all command in alphabetical order in the middle.
Find the Archicad Movie Player and press the ADD button.
After you OK all of this you should find the Movie Player in the Options menu.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-01 04:13 AM
Select the "Command Layout scheme" on the left and then "Store as" on the right and give it an appropriate name.
Then when you want to use it open the Work zenvironment, select "Command Layout scheme" on the left, select the scheme you saved on the right and press the "ApplyScheme" button.
You can also save it as a completely new Work Environment but I will let you sort that one out.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-01 04:20 AM
Do this to create a new profile.
The just open Work Environment and apply the new profile whenever you want the movie player.
You have to creat a new one because the standard one is locked and can't be edited.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-01 06:50 PM
But I am using the INT version.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-10 01:23 PM
Hi. I am trying to follow ArchiCAD Essentials ITG e-Guide and have been able to get chapter 1 open in Archicad Movie Player within the Archicad 14 (edu) environment. How to I get Movie Player to open chapter 2 within AC environment? I have open chapter 2 from the view map, but am still getting chapter 1 on AC Movie Player.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-10 10:05 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-11 01:05 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-13 08:07 PM
I was working well with movie player in work environment today going through chapter 5 of Essentials Basic ITG. I saved and closed down half way through this chapter and now when I open and try to use Archicad Movie Player it shows on the bar (forget the name of this bar!) below the work environment but won't appear within work environment no matter what I do - maximise, restore, size etc....
I have tried closing and reopening the file and other files and I still can't get it to operate within work environment!
Where am I going wrong here?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-15 07:52 PM
