FONTS
A client that I draw for wants me to use Handsf single font. It works fine for everything except publishing, all the text is left off. I have a full version of adobe printer so if I print page by page the text will print. Is there any way to get it to go through the publisher. If i set up a print to adobe in the publisher it will not print to a single file and i have to wait for each page and then redirect it to the file and then add the pages into one file to send.
1 REPLY 1
Srinivas
Hi Gary,
Although not a direct solution, did you try printing with multiple layouts selected?
1) Select your layouts from the navigator or the organizer
2) Ctrl + P, select the option "Selected Layouts in Navigator"
3) Also from the properties tab try to embed the font into your adobe drivers.
ArchiCAD had issues publishing some fonts when published with the built in publisher since v11.
Hope this helps.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
