Facade with recess?
I'm trying to model a facade which has a recessed panel/window.
Reference project:
How can I model such a facade/window correctly in archicad 22? I could just use a flipped facade element for the recess and place it next to a normal facade but I think that wouldn't be a good solution.
I found a setting to recess a windows inside a facade element but there is always a small frame left. Also, the fixed panel below can't be recessed.
Even if I create my own profile, I can only have one layer where the panel gets placed but in case of the middle post, I would need to place the window in the back and the fixed glass in front.
0 REPLIES 0
