Fast Offset
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-08-21 02:27 PM
2010-08-21
02:27 PM
Is there any method or shortcut offsetting lines easily in one command like in Autocad?
I had a wish about this "offset" command before but many Archicad users said " forget Autocad when you're using Archicad "
Ok ! completely accepted, but this offsetting method of Archicad drives me crazy
I only want Autocad's offset method in AC. May be there is a way but i don't know or i can't use.
your ideas? suggestions?
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-08-21 02:49 PM
2010-08-21
02:49 PM
put a personal shortcut to the offset command and by using the magic wand its quite fast.. also.. if you need multiple offsets.. you can either use the multiply command or there's an multiple offset command too
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-08-21 04:27 PM
2010-08-21
04:27 PM
ogabson,
Have you looked at the Help file, under New Features, General Productivity, Easy Offset?
Archicad works differently (duh...), learn the differences and you'll soon be working just as quickly: 1) there is the offset of slabs, roofs etc though the pet palettes, 2) then offset of lines through the magic wand and 3)and the drag a copy for walls, lines, etc. More things to remember, but once you get on with it, just as versatile.
I had the same "offset" frustration, until I just stopped, really stopped wanting to do it the Autocad/Microstation/whatever way, get your mind into the Archicad way. You will increase your expertize and speed with the program.
Snap
Snap
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-08-21 05:27 PM
2010-08-21
05:27 PM
Thank you Snap and Enrique,
I had problems generally 2D lines,polylines. I haven't known using the magic wand tool for offseting
I hope i'll fix my mind as soon as possible
Thank you again both of you for your guidance.
PS.
WOW! it works well
PS.
WOW! it works well
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-08-27 04:23 AM
2010-08-27
04:23 AM
You might also like this video on ways to use offset:
http://www.youtube.com/watch?v=k2cm1qoQvVo
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
bT Square Peg
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-09-01 02:10 AM
2010-09-01
02:10 AM
Thanks Vistasp,
nice video about offset
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-09-09 11:30 PM
2010-09-09
11:30 PM
thank you
this is very important
