‎2010-09-09 02:00 AM
‎2010-09-09 06:04 AM
/Users\<user>\Library\Preferences\Graphisoft\AC xx.0.0 yyy v1 folder - this folder contains the basic preferences files and all the Work Environment filesHope this helps.
/Users\<username>\Library\Preferences\com.Graphisoft.AC xx.0.0 yyy v1.plist where xx stands for the version number of ArchiCAD, yyy is the localization of ArchiCAD - this file contains some basic settings of ArchiCAD. The Windows equivalent of this file are the Registry keys
/Users/<username>/Library/Caches/Graphisoft folder - this folder contains library cache files and the local cache copy of network libraries
/Users/<username>/Library/Application Support/Graphisoft folder - this folder contains the Archicad autosave folder, the ArchiCAD templates, the DXF-DWG translators, IFC preferences, Bug reporter log files, publisher log files. Note: You may want to back up this folder in order to keep your Work Environment files and DXF-DWG translators
‎2010-09-09 10:07 PM
