Favourites palette
Hi All,
I think the favourites palette is a great idea, however I'm finding it a bit temperamental when it comes to saving favourites for slab's. I want to save a list of slab types:
ceilings @ 28c, 31c, 32, floor slab @ 0c (100mm thick) and so on ...
I am able to save the favourites no problem and when the mouse goes over the list I can see the settings changing to my saved settings, however after I double click the slab i want and go to draw the setting change back to a previous default.
This only appears to be happening on the slab tool as I try selecting a pre-saved dimension, column or beam and there are no dramas
Any suggestions, or is this a know bug ? Would appreciate some response from ArchiCAD rep if possible.
0 Replies 0
