File backup techniques
I like to save my file periodically as a separate file, marking it with a date etc. However, I would like to be able to save my file directly to my backup folder, while continuing working from the current file, (where currently it automatically transfers to the recently saved file) mainly to help with keeping my folders neat and organized. Is there a way to select which file stays open?
Thanks for any comments.
13 REPLIES 13
No. Like almost every program for Windows and Mac (up until Mac Lion), when you Save As, the newly saved-as file is the active one.
You'll have to do a Close after the Save-As and then open the 'active' file from the Recent Files list.
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Or you could "save as" with the new file name and location and then immediately "save as" again with the old file name and location.
Or you could just copy the open file in Windows Exporer (or the Mac equivalent) and rename it.
It doesn't matter if the file is currently open in Archicad.
This way you don't have to open/close or save as files in Archicad at all.
Gorazd
It would really be nice if ArchiCAD would have some kind of backup plan. To save very hour to some backup folder, and keep last few backups. With the available space on drives theese day it would save people from potential troubles big time. It is awailable in teamwork, why just not expand this for non TW users.
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
vistasp
Windows users might find this discussion on version backups useful.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Did you mean to link to another post?
vistasp
Whoops! Thanks Barry!
And here's the link.
http://archicad-talk.graphisoft.com/viewtopic.php?t=34929
= v i s t a s p =
bT Square Peg
I'm still using this way, a Global Method, I think, for all software.
Gorazd
Time Machine is one of the things I miss most from my former MacBook 🙂 I am using some backup techniques, but still it would be nice to have versions backup to any SW, not only ArchiCAD
Gorazd Rajh
I do this too... Just drag a copy of the file into my backup folder and add the date to the file name...
