Fills problem
lmcardoso
Hi
I opened a archicad 14 file in archicad 15, and i have been working on that file but i have a problem because I dont have any fills.
I only have the possibility of having 100% 50 25%, but i dont have the wood or steel or brick fills?
do u know how can i fix this?
thanks in advance
Luis
ArchiCAD 23/25/27 with Win 10
Open a new archicad using the default Graphisoft template and save it as an empty document on your desktop call it "untitled" for example. then using the Attribute Manage (Options>Element Attributes>Attribute Manager) , import the fills you need from the empty "untitled" file.
hope that helps..
lmcardoso
it worked. thank you very much
